Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
brum
Nov 18, 2009Aspirant
Nemo7777,
The Duo streams .mkv files to the PS3 without problems. The problem is, however, that the PS3 cannot read .mkv files. Since the Duo's CPU isn't fast enough to do real-time re-muxing or re-encoding, the short answer to your question is 'no'.
You need to either continue using mkv2vob first, or use a separate computer with some media server, until Sony releases .mkv support for the PS3.
Rgds,
brum
Rgds,
brum
