Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
chmmrt
Nov 19, 2009Aspirant
I convert and burn to optical disc with multiavchd.
It's the only thing I've found that converts DTS to AC3 and deals with subs.
Sometimes you need to play around with the bit rate settings to get a avchd that will fit to 8152mb though
