Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
chmmrt
Nov 22, 2009Aspirant
brum wrote:
chmmrt wrote: I convert and burn to optical disc with multiavchd.
It's the only thing I've found that converts DTS to AC3 and deals with subs.
Sometimes you need to play around with the bit rate settings to get a avchd that will fit to 8152mb though
Why would one want to convert DTS to AC3 when it's not necessary? AC3 is inferior, and transcoding between two lossy formats further adds degradation to the sound. mkv2vob can burn the subtitles for you, but will preserve DTS a default (but can also transcode).
Rdgs,
brum
http://forums.afterdawn.com/thread_view.cfm/683259
