Nemo7777
Jun 02, 2009Aspirant
What addon can stream 'mkv' file to PS3
Hi there, I can see a lot of add-ons for READYNAS DUO (RND), but can somebody tell me - which of them can really stream mkv video files to PS3? No matter is it will be freeware or shareware software,...
fdullemond
Nov 24, 2009Aspirant
Unfortunately, PS3 media center does not run on a readynas (NV+ & DUO). Prerequisites and missing CPU power are the main problems.
(I am not sure about NVX & PRO.... I guess prereqs will be the problem here.)
Of course its not convenient to run a separate program on yet another PC for trans-coding unsupported video formats, but that is just a minor inconvenience I gladly choose over active re-encoding files in batch runs.
