theonlyjustin
Aug 02, 2015Initiate
WINDOWS 10 - ReadyNAS Remote not connecting
Initialization Failed.
For more information, please visit:
http://readynas.com/remote
Error Code: -3
Since updat...
bjw822
Aug 05, 2015Initiate
Fought with this for 2 days and then reverted back to Windows 7. I have a duo v2 and I tried everything suggested in this post during the time I had it installed. Nothing works. Luckily I had a openvpn setup to my router. I had to connect and use the ip address in windows explorer to transfer files that I needed.
My only suggestion is to go back to your previous OS - but you will be fight with other things then. Like every task in the Task Scheduler being corrupt.
Or setup a different way to remote in. My router has openvpn built-in and is easy to configure. Only 5 connections though.
I hope Netgear does update the legacy remote so I can upgrade. I like a lot of the things on windows 10, but I am not ready for a new NAS.
