theonlyjustin
Aug 02, 2015Initiate
WINDOWS 10 - ReadyNAS Remote not connecting
Initialization Failed.
For more information, please visit:
http://readynas.com/remote
Error Code: -3
Since updat...
JennC
Aug 05, 2015NETGEAR Employee Retired
Hi eonlyjustin,
ReadyNAS Remote for legacy ReadyNAS devices is already EOL, although it still runs and can be used there will be no further update anymore since it has been replaced with ReadyCloud.
We apologize but it appears you cannot use ReadyNAS Remote on a Win10 machine.
theonlyjustin
Aug 10, 2015Initiate
Thanks go it working now. Cheers for everyone's help
- mdgm-ntgrAug 11, 2015NETGEAR Employee Retired
ReadyNAS Remote users who have updated to Windows 10 can try this beta app: https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/ReadyNAS-Remote-Windows-App-Beta/m-p/970692#M14046
- jcaleySep 03, 2015Aspirant
I tried beta. Running windows 10 pro aiming to connect to Netgear readynas duo.
When I launched the App I got the following message:
"The task object version is either unsupported or invalid. (Exception from HRESULT: 0x80041313)"
- poprockfmSep 07, 2015Aspirant
I got the same issue. On my laptop and desktop pc With my desktop i can acces my nas via the task manager by tiyping in \\192.168.2.1 than i get connection , i can ping it and also via webbrowser is accesible ,
But it's not via the file explorer. What is going on .
Goos
- May 19, 2018Retired_Member
