theonlyjustin
Aug 02, 2015Initiate
WINDOWS 10 - ReadyNAS Remote not connecting
Initialization Failed.
For more information, please visit:
http://readynas.com/remote
Error Code: -3
Since updat...
theonlyjustin
Aug 10, 2015Initiate
Thanks go it working now. Cheers for everyone's help
mdgm-ntgr
Aug 11, 2015NETGEAR Employee Retired
ReadyNAS Remote users who have updated to Windows 10 can try this beta app: https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/ReadyNAS-Remote-Windows-App-Beta/m-p/970692#M14046
- jcaleySep 03, 2015Aspirant
I tried beta. Running windows 10 pro aiming to connect to Netgear readynas duo.
When I launched the App I got the following message:
"The task object version is either unsupported or invalid. (Exception from HRESULT: 0x80041313)"
- poprockfmSep 07, 2015Aspirant
I got the same issue. On my laptop and desktop pc With my desktop i can acces my nas via the task manager by tiyping in \\192.168.2.1 than i get connection , i can ping it and also via webbrowser is accesible ,
But it's not via the file explorer. What is going on .
Goos
- StephenBSep 07, 2015Guru - Experienced User
You do need to be careful with the slashes. \\192.168.2.1 will connect with SMB, //192.168.2.1 will open your web browser.
Also, try to use just one thread please.
