theonlyjustin
Aug 02, 2015Initiate
WINDOWS 10 - ReadyNAS Remote not connecting
Initialization Failed.
For more information, please visit:
http://readynas.com/remote
Error Code: -3
Since updat...
PGB99
Aug 18, 2015Aspirant
Not only did the beta fix work, it works better than the old readynas remote. It seems to automatically reconnect more seamlessly.
Thanks Netherlands.
Now if you can get the Android app to work as of, that would be great!
Thanks Netherlands.
