77PALE77
Jul 24, 2023Apprentice
Zero Tier not working on RN104
Hi everyone, just updated my RN104 to 6.10.9 firmware, hoping this would solve the problem, but Zero Tier "nastools-zerotier-one_1.1.14-nt3_armel" cannot be installed on my NAS. Any suggestion...
Sandshark
Jul 24, 2023Sensei
See How-I-got-apt-update-and-install-to-work-with-Debian-Jessie and ZeroTier-as-a-ReadyCloud-replacement.
I recommend you go with a much newer version, as outlined in the second referenced post. Even if you do the sources update in the first, I don't think you can upload the one you have from the GUI, but you can from SSH.
- 77PALE77Jul 25, 2023ApprenticeHi,
I’m really not familiar at all with SSH.
As far as I can understand I only need to activate it on the NAS and then somewhere there will be something like a command line.
Reading the second post I understand that in this command line I only have to paste
curl -s https://install.zerotier.com/ | bash
zerotier-cli join <yournetworkID>
zerotier-cli info
and it should work.
Did I get it right?
Thanks- StephenBJul 25, 2023Guru - Experienced User
77PALE77 wrote:
As far as I can understand I only need to activate it on the NAS and then somewhere there will be something like a command line.Yes (the linux command line). Log in as root using the NAS admin password.
zerotier-cli info
and it should work.That was true at the time, but is more complicated now. You need to install these mods:
Also, curl no longer works, you need to download and manually install the appropriate deb file. What model ReadyNAS do you have?
- SandsharkJul 25, 2023Sensei
There have been events that have made the original instructions no longer valid, and they are covered in the entire thread. On these forums, you can't just read the first post, as modification may follow. Users can't modify their posts with new information once anyone has responded or after some time frame that seems to be only minutes. I realize it's a long thread and can get confusing. In the thread for updating the Debian repositories, I recently posted a "where we are today" post. Maybe I should look to do the same with that one.
