dannas1
Sep 16, 2013Tutor
.htaccess to hide share folder
hi all, just after a bit of help with removing the share folder showing up in http requests. so http://mydomain.com/mywebshare/ would so as http://mydomain.com plus any other pages would not...
Sep 20, 2013Guru - Experienced User
I think I'm still a little confused.
-are you using the NAS to host your own web server?
-are you wanting to access some or all of the shared folders over http?
I am kind of thinking that all you want to do is prevent http://mydomain.com from redirecting to http://mydomain.com/mywebshare But I am not sure.
Do you have an arm-based NAS (duo v2). That seems likely. This guide might help: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/ If so, you might want to update your profile. The v1 (sparc) duo is quite different.
