JD168
Jul 11, 2018Follower
++ ReadyNAS REMOTE - ReadyCLOUD ++
Hello, I want to setup an older ReadyNAS Pro 6 (ReadyNAS 516) for use with ReadyNAS Remote or ReadyCLOUD. Model name: RNDP6000 Model no: RND-6B
RAIDiator 4.2.31 on it.
ReadyNAS Remote ist ...
- Jul 11, 2018
Hi JD168
Welcome to the Community!
ReadyCloud service is not available for RAIDiator 4.x, it is only available on OS 6 and that is why you are not able to register and connect your Pro 6.
You can opt to upgrade your Pro 6 to OS 6 Firmware. Please see this thread.
Please note that this procedure is not supported by NETGEAR so you will have to do it on your own risk but members here can advise you what you can do and we have members who have upgraded their x86 legacy NAS. A factory reset will be done once you have upgraded to OS 6 so your data will be lost, make sure you have full backup before doing this.
You can also setup VPN Connection using OpenVPN or ZeroTier so you can have connection to your remote location. See this thread.
Hope this helps!
Regards
Marc_V
Jul 15, 2018NETGEAR Employee Retired
HI JD168
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
