Helevitia
Apr 23, 2016Aspirant
10 yr old RN-NV stopped working after power loss. What are options to get XRAID drives working again
Hey everyone! I actually bought my REadyNAS NV in october of 2006. There was the PSU fiasco after a year, but after replacing the PSU, it has been chugging along ever since. The only other hting I...
- Apr 23, 2016
XRAID is layered on top of standard RAID modes. You can access your data from an x86 linux system: http://home.bott.ca/webserver/?p=306
The RN104 isn't compatible with your disks (the CPU is different, and the data volume disk is formatted differently). However, Netgear support can help if you are migrating your NV+ data to a new OS6 platform. There is more information here: http://kb.netgear.com/app/answers/detail/a_id/29876
Apr 23, 2016Guru - Experienced User
- HelevitiaApr 23, 2016Aspirant
Awesome, thanks! Exactly the kind of info I was looking for. Have a great day!
- HelevitiaApr 28, 2016Aspirant
Quick question. If I access my data via linux, it doesn't talk about how to setup the drives physically? I'm assuming x-raid is just raid 5? Do I need to plug the drives in order and then do I need to do anything in linux such as software raid 5 before trying to mount the drives?
- StephenBApr 28, 2016Guru - Experienced User
I don't think the order matters.
Technically the NV V1 xraid uses RAID-4 (because it has a dedicated parity disk) but we usually call it RAID-5 here (and flexraid for the v1 also calls it RAID-5 in the admin ui and the manual).
- HelevitiaApr 29, 2016Aspirant
Hi Stephen,
I appreciate your help in this. I have found an old NV+. Assuming it is the same that I had, can I just pop the drives back in? Is the metadata on the drives? Thanks!
