Calder
May 20, 2018Guide
100% CPU usage every 24 days
Hi,
Every 24 days both of my RN104 will eat up 100% CPU within 5 minutes of each other. I do not have any scheduled tasks on them at all. The only remedy is to restart them. Anyone having the sa...
yxue
May 20, 2018NETGEAR Expert
Did you install any apps? Did you enable anti-virus?
Calder
May 21, 2018Guide
No apps, no AV, just plain jane iSCSI and SMB. =)
- StephenBMay 21, 2018Guru - Experienced User
There are some scheduled activities that you can't manage from the web UI (for instance SMART status, NTP time updates, and similar stuff). But I can't think of anything on a 24 day cycle.
Perhaps PM mdgm-ntgr or another Netgear mod, and ask if they are willing to look at your logs.
- JohnCM_SMay 23, 2018NETGEAR Employee Retired
Hi Calder,
Can you provide to us the logs? You may check this link for the procedure on how you can send it.
- CalderMay 23, 2018Guide
Thanks and yes, logs sent as per instructions via link.
- evan2May 23, 2018NETGEAR Expert
Could you please access NAS via SSH and run command "top" to check which process use CPU recourse when the issue happen?
Enabling SSH access for root using password authentication.
- Go to System > Settings > Services.
- Click on SSH.
- When prompted with the support warning, click Yes if you are sure you want to proceed.
- Select Enable SSH and Enable password authentication.
- Click Apply.
- You can now connect to the ReadyNAS through SSH as the root user.
Note: The root password is the same as the admin password
You may use tool putty access SSH.
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
