tjsnow
Sep 23, 2016Aspirant
1002030001 - Commit Failed #27399265
I recently changed a hard drive and lost all volume information. I worked with support to get htis issue resolved and the issue was quickly closed. I had not done a lot of testing past verifying my d...
tjsnow
This is a symptom that showed up because of thefix put in place from the original case. I have not opened a new one, I was going to reach out to support to re-open the case if I didn't find an answer here. The original case # is 27399265
JennC
Sep 24, 2016NETGEAR Employee Retired
Hello tjsnow,
How do you move the files? Is that from one share to another? Is that through the admin page or Windows explorer?
- tjsnowSep 24, 2016Aspirant
Using windows explorer, I have multiple shares. In one of them I cannot create a file, nor can i moe a file from a parent folder to a sub folder. In another share this works just fine. I assume this is a permissions thing (tho it worked fine before they rebuilt my volume). So I go in to modify the permissions and that is when I get the error mentioned above.
Using the admin panel does not work either. I tried to drag one folder into another and it fails to move without any error, the folder just refreshes with no change. Same thing happens when I click the button to crete a new folder. the page just refreshes and no new folder is created.
Additional note, I just verified that I am unable to edit/move files in any of the shares. If I try to create a file, it sais I do not have permisisons (tho the admin panel shows that read/write is enabled for everyone. If I try to rename a file (any file) I get an error that the file is in use in another program. I have already verified all my backup scripts are not running, and that nothing is using the files. But I still cannot change anything. It is as if I have read only on everything no matter what the admin panel shows. I also cannot change any settings in the admin panel because of the error mentioned above.
- mdgm-ntgrSep 25, 2016NETGEAR Employee Retired
Can you send in a fresh set of logs (see the Sending Logs link in my sig)?
Do you have a backup?
