tjsnow
Sep 23, 2016Aspirant
1002030001 - Commit Failed #27399265
I recently changed a hard drive and lost all volume information. I worked with support to get htis issue resolved and the issue was quickly closed. I had not done a lot of testing past verifying my d...
mdgm-ntgr
Sep 26, 2016NETGEAR Employee Retired
This was not caused by what support did.
You've been getting volume usage warnings for a long time, long before you opend your support case. In status.log I can see lots of volume usage warnings. Here are the ones from when you first were warned about volume usage exceeding 90%
[14/12/18 11:57:14 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [14/12/19 22:24:19 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [14/12/30 07:53:00 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/01/08 16:49:28 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/01/15 13:13:36 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 80 % of size (7.9 TB). [15/01/22 15:33:17 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 80 % of size (7.9 TB). [15/04/03 14:37:29 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/04/14 13:24:10 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/08/10 13:17:19 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/08/10 13:37:31 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/08/14 21:33:38 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/08/14 21:49:30 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/08/14 23:08:12 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/08/20 13:30:56 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/08/25 14:27:00 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 95 % of size (7.9 TB). [15/09/19 12:50:41 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/10/03 17:11:16 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/10/26 17:50:36 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/11/02 18:57:24 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume 'data' usage exceeds 90 % of size (7.9 TB). [15/11/27 23:38:04 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (7.9 TB). [16/01/05 16:17:55 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 90% of size (8.0 TB). [16/01/05 16:30:43 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 90% of size (8.0 TB). [16/01/25 12:27:23 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/02/21 01:27:13 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/02/21 04:00:44 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/05 04:49:18 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/05 06:57:00 MST] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/23 16:24:23 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/25 10:51:22 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/25 11:21:42 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/25 11:25:42 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/03/30 16:24:22 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.0 TB). [16/04/21 01:47:32 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 90% of size (8.1 TB). [16/04/28 10:47:29 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/05/01 18:37:44 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 90% of size (8.1 TB). [16/06/06 13:57:33 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/06/11 15:54:41 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/07/04 15:15:20 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/07/04 15:40:25 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/07/08 13:39:10 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/07/21 10:24:12 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/07 17:19:34 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/10 16:28:13 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/21 18:24:18 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/21 21:57:45 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/23 10:09:02 MDT] warning:volume:LOGMSG_VOLUME_USAGE_WARN Volume data usage exceeds 95% of size (8.1 TB). [16/09/23 10:53:27 MDT] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 5% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity. [16/09/25 23:51:28 MDT] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 5% of volume data's capacity is free. Performance on volume data is degraded. To improve performance, you must add capacity.
Considering all that's happened, that you've said that your data volume goes immediately into read-only mode even after a reboot, and that your volume was setup back on 6.0.1, I think backing up, doing a factory default (wipes all data, settings, everything) to get a clean setup on 6.5.2 and restoring your data from backup is the best way forward from here.
Can you access the data you are having trouble accessing if you login as the 'admin' user?
You should keep volume usage down to about 80-85%.
tjsnow
Sep 29, 2016Aspirant
I was able to access the files. So I bought some external drives to plug in and back up before I wipe and start over. When plugging in the drive everything went back to red and the system says no volumes found.
After reviewing the logs, it didnt fail at the time I plugged in the drive, it failed while backing up files to amazon cloud. The error states that "Volume: Bit rot has detected an error within /data/xxxxxxxxxxx.xxx and cannot correct the error. At this point the whole nas was inacessible. I performed an OS reinstall and was able to access the admin page, but nothing else. Curently states no volume information found. Now I am back to where I started 3 weeks ago.
I was told to back up my files and it failed while doing so.
