zorro1
Jan 05, 2015Aspirant
16TB limit?
Hi, I have 2 x 6-Bay Business Edition Nases, and I would like to know if there is way to check if they have a 16TB volume limit. Thanks very much.
RX
Jan 05, 2015Luminary
If I am not mistaken, Volume Expansion will not work beyond 16TB. In order to support 16TB or greater, you will have to factory reset with that capacity in place. This is due to the limitation of the EXT4 filesystem tools that are used to expand the filesystem.
Also, it would be advisable to have your NAS on the latest FW v4.2.27.
