zorro1
Jan 05, 2015Aspirant
16TB limit?
Hi, I have 2 x 6-Bay Business Edition Nases, and I would like to know if there is way to check if they have a 16TB volume limit. Thanks very much.
Jan 05, 2015Guru - Experienced User
There are two expansion limits for your ReadyNAS.
zorro wrote: I have 2 x 6-Bay Business Edition Nases, and I would like to know if there is way to check if they have a 16TB volume limit.
One is that a volume growth is limited to 8 TiB over its lifetime. The second is that a volume cannot grow over 16 TiB.
You can create a larger volume size than 16 TiB if you use disks of the same size, and do a factory reset with them all in place. That volume can't be expanded though.
Note the above limits are on the actual volume size, not the raw disk capacity. For instance, 6x3TB single redundancy is under to 16 TiB limit, as is 6x4TB dual redundancy.
