zorro1
Jan 05, 2015Aspirant
16TB limit?
Hi, I have 2 x 6-Bay Business Edition Nases, and I would like to know if there is way to check if they have a 16TB volume limit. Thanks very much.
RX
Jan 26, 2015Luminary
It seems that 6TB disks are currently not supported on ReadyNAS Pro Business Edition.
Kindly check this link: http://www.readynas.com/app/hcl_disk
As per StephenB's earlier response on this forum:
StephenB wrote: You can create a larger volume size than 16 TiB if you use disks of the same size, and do a factory reset with them all in place. That volume can't be expanded though.
