zorro1
Jan 05, 2015Aspirant
16TB limit?
Hi, I have 2 x 6-Bay Business Edition Nases, and I would like to know if there is way to check if they have a 16TB volume limit. Thanks very much.
mdgm-ntgr
Jan 26, 2015NETGEAR Employee Retired
It creates a 6x4TB RAID-5 layer then tries to expand to add a 2x2TB RAID-1 layer using the remaining 2TB on each of the 6TB disks. That fails.
You can do a factory default (wipes all data, settings, everything), open RAIDar, click setup during the 10 minute countdown, choose Flex-RAID and confirm your choice. Delete the volume created by default and create the ones you want.
Another alternative is to put OS6 on your Pro units (also requires a factory default). However this is unsupported.
