Ukeyoner
Jun 10, 2017Aspirant
1GbE speeds over 10GbE connections? MacOS
I was wondering if anyone is having this same expereince. I have a new 626x, all drives filled, x-raid, connected to a Netgear XS708E 10GbE router, and I'm getting very slow speeds over 10GbE. Not ev...
- Jun 12, 2017
mdgm wrote:
I was thinking e.g. a 5400RPM hard disk in an iMac could be a bottleneck.
I agree that could easily be it. iPerf would measure just the network, so the disks in the NAS and the iMAC wouldn't factor in - so it would help isolate the cause.
Can you copy from the thunderbolt RAID array to the NAS? That's another way to take the imac disk out of the equation.
mdgm wrote:
With Jumbo Frames finding the right MTU for your environment can take a bit of work. I'm not sure if/how well Jumbo Frames work with 10G.
Though they should work just fine, I see no need for them with 10G. So I would just turn them off, and use the normal 1500 MTU.
Also, if iPv6 is enabled in the NAS, try disabling it.
Ukeyoner
Jun 11, 2017Aspirant
I emailed the logs.
I'm using Cat 7 calbles actually.
In my mac network utility it states a 10 Gbit/s link speed.
On my router all the lights are greenm which on the XS708E indecates 10GbE supposedly.
Thank you for your time.
-Mike Czerniuk
mdgm-ntgr
Jun 11, 2017NETGEAR Employee Retired
The logs were not attached to your email.
- mdgm-ntgrJun 12, 2017NETGEAR Employee Retired
The logs show a 10GbE connection.
Could the hard disk in your Mac be the bottleneck?- StephenBJun 12, 2017Guru - Experienced User
If you are comfortable with ssh, you could try installing iperf on the NAS and the Mac. That would let you see if this is a network issue or not.
- UkeyonerJun 12, 2017Aspirant
I don't know anything about SSH. I would need to look into that. I am thinking that I have some settings set up wrong on one end or the other, I just can't figure out where.
I'm not sure how the Hard drives could be the bottleneck. I did throw in a mix of hard drive sizes for testing, but all of them are sata 3 and 7200 rpm. I would imagine 6 drives in raid 5 should be able to go faster than 90MBs.
I have a half full 6 bay thunderbold 1 drive in a raid 5 that does 400MBs over a thundeboldt 2 connetion. I was hoping an emoty 626x would be ablt to go almost as fast as that.But I agree the 1Gb speeds is showing a bottleneck somewhere.
