123BigRed
Aug 26, 2011Aspirant
1TB usb drive formats to 193 GB EXT3
So if I format the HD attached directly to my Mac or to the Airport Extreme I see the normal 1TB size and approx 999GB free, however when I attach it to the readynas duo I only see 193 GB available, a...
mdgm-ntgr
Aug 26, 2011NETGEAR Employee Retired
Connect the disk to your Mac again and format it again, this time under Options (I think) select to use MBR partitioning. Then connect it to your ReadyNAS and format it to EXT3 via Frontview again.
