carpii
May 30, 2015Tutor
2 disks died at once :(
I shutdown my ReadyNAS Pro 4 this morning (Radiator 4.2.27) , but when I rebooted it an hour later, 2 of the 4 disks were suddenly marked as dead. The NAS wasn't physically moved, and its on a UPS ...
BaJohn
Jun 02, 2015Virtuoso
That is one of the things that worries me 'long term', since I bought 7 disks together (6 + spare, see http://www.readynas.com/forum/viewtopic.php?f=24&t=80614) and obviously the 'end of life' will occur at a similar time. I am not certain that different batches of the same disk would make significant difference. Anyway it would mean buying from (worst or is that best, case) 7 different suppliers.
carpii wrote: I normally try to use identical disks but from different batches in my NAS, but looking at the serial numbers it looks like they all came from the same batch, so maybe thats a factor too
BaJohn wrote: Technically, switching on the drives is a stressor event, and they were both switched on together (I assume).
I almost wish I have a 'farm' of NAS systems so I could rotate them. :idea:
One other thought - maybe at start up there is a lot of vibration in your system. Maybe they ALL fire up together, or are they sequentially, either of which could be a problem if the mounting is not good. Possible some resonance occurred in the supporting desk/rack etc.
