netghiro
Nov 09, 2016Aspirant
2 way offsite replication
I'd like to use the built-in replication function in my readynas for replicating it to another offsite readynas. Would that be possible for the offline readynas to replicate it self as well into the...
FramerV
Nov 10, 2016NETGEAR Employee Retired
Hi netghiro,
You may want to try using Rsync for this.
Please let me know if this is what you need.
Nov 11, 2016Guru - Experienced User
FramerV wrote:
Hi netghiro,
It'd be better to use rsync over ssh: http://kb.netgear.com/app/answers/detail/a_id/29929
You can use this approach to back up some shares on ReadyNAS A to ReadyNAS B, and other shares on ReadyNAS B to ReadyNAS A.
It's not two-way sync though based on your earlier post I don't think you actually need that.
