Condiesit
Dec 03, 2015Aspirant
2 x ReadyNas 2120 V2 6.4.1 hangs, Major problems
Hi we have Major problems with our 2 2120 v2's the upgrade to 6.4.0 really caused issue's with the usb drives, we rant he beta for a shirt time which resolved these issue's but then caused the de...
JennC
Dec 03, 2015NETGEAR Employee Retired
Hello Condiesit,
Do you have any app running at the same time on these ReadyNAS units?
- CondiesitDec 04, 2015Aspirant
Hi
no apps running at all, we just use them for backup storage so they are not that far off a factory reset, just a share and ip address. we have had to give up using them for the moment.
again last night we had one server backing up to one of them and it hung during the night. rebooted this morning and a resync of the drive has started.
I am going to try a factory reset one of them and see if it helps at all.
any other sugestions?
Cheers
Tom
- StephenBDec 04, 2015Guru - Experienced User
Have you checked the disk health? It might also be useful to look for trouble in the logs.
disks all check out fine, I would be supprised if it was disks as it's happening on both as Drives
which logs should I check as when you download them there are loads to look at.
Cheers
Tom
