rdepas
May 20, 2013Aspirant
2100 power supply failure / replacement
Had a power supply fail in a 2100. Opened it up to see the capacitors were leaking which is a known issues with that model. I have a 250W Enhance ENP-7025B power supply on order. Using a standard PC A...
rdepas
I widened the net on my search and found some posts for the NV+ which sounded similar. Assuming the same holds true for the 2100 in that I just need to match up the wire colors on the new 20 pin connector to the old per this drawing:
http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
Also changed my order out for the Apevia ITX-AP250W 250W Flex ATX Power Supply which was rated better. Really miss having dual power supplies in devices like this. Nice to see Netgear putting them in their higher units.
