rdepas
May 20, 2013Aspirant
2100 power supply failure / replacement
Had a power supply fail in a 2100. Opened it up to see the capacitors were leaking which is a known issues with that model. I have a 250W Enhance ENP-7025B power supply on order. Using a standard PC A...
rdepas
Yes - it is using the seventeam power supply.
Would it be reasonable to think I can match up the 20 pin wire colors on the new power supply to the same as the old one? I will also reference your drawing but without knowing what the values are for Vcc, VSBY5, VCC3,... it is pretty hard to know exactly what values are being called out.
