rdepas
May 20, 2013Aspirant
2100 power supply failure / replacement
Had a power supply fail in a 2100. Opened it up to see the capacitors were leaking which is a known issues with that model. I have a 250W Enhance ENP-7025B power supply on order. Using a standard PC A...
chirpa
May 20, 2013Luminary
Ya, if you match it to the current one, you should be fine.
