Alfnie
Jan 07, 2019Aspirant
2nd ethernet port for backup data to other readynas?
Hi all,
I can't get the following setup to work:
I have read: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/dedicating-2nd-ethernet-port-for-backups-how/td-p/957428, but it...
Retired_Member
Jan 08, 2019Hi Alfnie, whatever you are trying to achieve will not work as long as you will have two clients on your network, which have the same ip-address. But from your post I see, that this is the case for Pro4 Ethernet port2 and NV+ Ethernet port. That is like using the same email address for two different people to send messages to them. Your router is not able to decide, where the IP-packages should go to.
Kind regards
