muzicman82
Aug 16, 2013Aspirant
2nd Ethernet Port
Hi all, I have a ReadyNAS 4 Ultra Plus. What are some of the uses of the 2nd Ethernet port? Is it only for making it available on two different networks/subnets? Can I use it to obtain better perfo...
Slasky
Aug 19, 2013Aspirant
If you want to isolate the traffic, you could set a different Vlan ID on the backup ports, but you would then need a computer in the "backup vlan" to check on the status, unless you set up a static route for the range you set for your backup network
