muzicman82
Aug 15, 2013Aspirant
2nd Ethernet Port
Hi all, I have a ReadyNAS 4 Ultra Plus. What are some of the uses of the 2nd Ethernet port? Is it only for making it available on two different networks/subnets? Can I use it to obtain better perfo...
Aug 19, 2013Guru - Experienced User
You could certainly do this. You could also put the backup device behind its own router, and forward the rsync ports, and https for management (which would be a little easier for most home users than learning about VLANs).
Slasky wrote: If you want to isolate the traffic, you could set a different Vlan ID on the backup ports, but you would then need a computer in the "backup vlan" to check on the status, unless you set up a static route for the range you set for your backup network
But I am personally not seeing the need to isolate the backup device on a home network, so I am wondering about why this is desirable. Knowing the use case might help.
