dmars
Oct 02, 2018Aspirant
2x RN422 wont connect for remote backup job
I just installed 2x 422 for my employer, one for the office for general file sharing and another off site at his house for backing up the office nas and its files.
The problem I am having is t...
- Oct 02, 2018
It might be easier to troubleshoot if you start with both machines on the same network. In your case, you will want to use either ReadyDR or Rsync over SSH.
Once you get a test backup job working on the local network, you can add in the port forwarding and the DDNS setup.
dmars
i have tried Ready DR, but with no luck
Oct 02, 2018Guru - Experienced User
- dmarsOct 02, 2018Aspirant
completly forgot about the ddns thx for the help!
