emoore
Apr 16, 2017Follower
3 ReadyNAS Duo V2
Hello, Came across 3 readynas duo on ebay for a great deal on ebay. model rnd-2b There all setup with firmware 5.3.12. Currently have one with 2 3tb hardrives on the raid 5 i tnink. only show 2.7t...
- Apr 16, 2017
emoore wrote:
Currently have one with 2 3tb hardrives on the raid 5 i tnink. only show 2.7tb avaible.
With a duo v2, it would have to be RAID-1. The web ui displays TiB (1024*1024*1024*1024 bytes), and of course the hard drives use TB (1000*1000*1000*1000). 3 TB is the same as 2.73 TiB.
emoore wrote:
So My question is how shall i set this up for the best setup at home? have one backup the other 2?
Personally I like to have one NAS sized to hold all my data comfortably (I'm using an RN526x for that at present).
Using some of the others as backup is a good idea (and I do that as well). if you set up share-by-share backup, then you can back up some shares on each of the backup NAS. If some shares are particularly important to you, you could them up on both.
emoore wrote:
buy a external drive for each as backup?
I think NAS->NAS backup is a better option (and you certainly have enough NAS to do that).
One aspect to consider is disaster recovery. You could use an external drive for that (keeping it off-site). Though cloud backup is another option. I use Crashplan for that (you could run it on a mac or PC, and map the NAS as a network drive. There are some KB articles on the crashplan site on how to set that up).
Apr 16, 2017Guru - Experienced User
