davidr1
Sep 14, 2015Luminary
314 - Shares and shortcuts on (linux) PC
Hi, Ubuntu NASUltra, NASPro, NAS314 6.2.4
With my Ultra and Pro, I could create shortcuts in my PC Home folder to Shares on the NAS'.
Please bear with me as I outline the procedure I us...
- Sep 15, 2015
Just deleting the shares/recreating them should work. Any snapshots should be deleted with the share.
Sep 15, 2015Guru - Experienced User
One simple answer is to delete them and recreate them.
You could also try changing their owner/group. Not sure if this is relevant - but "guest/guest" (and nobody/nobody) on the RN314 have different UID/GIDs from the pro's nobody/nobody. The RN314 uses 99, the pro uses 65534.
The default shares do seem to have some different attributes (if you use ssh, and do a getfacl on them you will see acl entries that don't exist for the shares you create). So you could also attempt to match their acl with financial, and see if that resolves it.
davidr1
Sep 15, 2015Luminary
Thanks StephenB.
My apologies for neglecting to give you the credit for the change from .../c/... to .../data/...
Yes, I had to use ssh and change the 'david' UUID on my Ultra (and Pro? from memory) to 1000 to match my UUID on Ubuntu.
I tried changing user/group before I posted but no combination worked.
I think, as you say, deleting the default shares and creating new shares is the easiest. I didn't want to ssh into the box becsause of the warranty ... I don't know how strict Netgear is. On my Ultra and Pro (which is still under warranty) I do it quite happily.
Is there a Rubbish Bin we need to worry about?
Many thanks - I appreciate your help.
David
- Aug 22, 2020Retired_Member
