Petroc
Jan 12, 2023Aspirant
324 cpu architecture error - not booting.
anyone encountered this error cpu_srchitecture+10? is my mas bricked?
Jan 13, 2023Guru - Experienced User
Try powering down, removing the disks (labeling them by slot), and powering up diskless.
Does the NAS display show a no disks detected message? If it does, the NAS is probably not bricked (and the error is disk-related).
- PetrocJan 14, 2023Aspirant
Thank you Tehen, knowing I had back ups of my shares a bit the bullet and turned the unit off at the plug as luck would have it it rebooted and resynced without error and has been running without issue since it apparently no data loss if it happens again, I will take your advice. And only had this error message about the CPU architecture. Strangely, there is nothing in the logs either.
