IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
IanSav
Dec 10, 2010Apprentice
Hi Jedi Knight,
Apart from the password reset what other, if any, changes are made to the ReadyNAS on OS/Firmware reinstall? Can *all* the changes be recovered/fixed by recovering a configuration backup?
I have already offered VNC access to a PC, Slingbox access to a PVR and ReadyNAS access to the 4.1.7 DUO for Netgear engineers to explore the issue. Are you asking me to re-offer the access via a support ticket?
Ian.
Jedi Knight wrote: I still am not able to reproduce the issue in house. I tried with Disk Spindown Mode. I tired with Jumbo Frame. If you could try with Frimware reinstall again and test with Direct connect (the ReadyNAS to PC) to rule out any possible switch/router issue. I also would advise rebooting the Clients before doing any test. If you are still having an issue, please open the tech support ticket (post the ticket info here) so that we can contact each of you and try to debug your system.
If anyone have same issue, please open a new post.
Ian.
