IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
IanSav
Dec 11, 2010Apprentice
Hi Sean,
Or Netgear are concerned about the process of reverting to the previous firmware.
I have just verified your observations. I toggled CIFS off and then on (within a few seconds) and I can now find and access shares on the DUO from my PVRs. As you said, this is a hack but it does help with the immediate problem.
Hopefully this will give the Netgear engineers something more with which to work.
Ian.
arsenicrun wrote: I am getting the impression that the lack of response to the questions about downgrading to 4.1.6 means that the answer isn't really clear.
arsenicrun wrote: Assuming you tend to leave your ReadyNAS Duo turned on for eternities at a time like I do, toggling the CIFS service on and off seems like a useful (although far from acceptable) fix. I've had instant-access all evening, and I am also fortunate enough to have mine connected to a battery backup so that I doubt I will have to worry about this until I am forced to reboot.
Ian.
