IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
Jedi_Knight
Dec 12, 2010Tutor
Guys,
We have been looking into this issue in-house. The only thing I can think of is was somehow samba daemon become unresponsive after reboot (or) doesn't get started correctly (however, if you restart the services by manually, it works fine). So I am not sure unresponsive or doesn't get started correctly due to smb.conf setting in your individual system.
Some of you have an issue with full root, so that update my not work properly. So I would suggest reinstalling the firmware.
OS Reinstall doesn't touch your data volume, however, it helps reset some configuration files that is being corrupted or need to update.
