IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
WSJ
Feb 14, 2011Tutor
I've just reproduced the issue, again.
In smbd.log I've found the following entries (created during the relevant time frame):
Remarkable: the "lib/util_sock.c" error entries.
18:45:24 - 18:46:50: 86 seconds waiting time. That's how long it took for the SMB network discovery.
([xxx] - I've replaced the actual username by 'xxx', '192.168.2.115' is the IP address of the PC requesting the share from the NAS)
At 18:47 I've stopped and restarted the CIFS service, see daemon.log (same in system.log):
After that, access to the shares worked - and in smbd.log there are no more "lib/util_sock.c" error entries.
("NAS" is the hostname of my ReadyNAS Duo)
network_settings.log does not show any network problems:
[2011/02/14 18:45:24, 0] lib/util_sock.c:get_peer_addr(1334)
getpeername failed. Error was Transport endpoint is not connected
[2011/02/14 18:45:24, 0] lib/util_sock.c:write_data(562)
write_data: write failure in writing to client 0.0.0.0. Error Connection reset by peer
[2011/02/14 18:45:24, 0] lib/util_sock.c:send_smb(871)
Error writing 4 bytes to client. -1. (Connection reset by peer)
[2011/02/14 18:45:51, 2] auth/auth.c:check_ntlm_password(309)
check_ntlm_password: authentication for user [xxx] -> [xxx] -> [xxx] succeeded
[2011/02/14 18:46:24, 0] lib/util_sock.c:get_peer_addr(1334)
[2011/02/14 18:46:24, 0] lib/util_sock.c:write_data(562)
write_data: write failure in writing to client 192.168.2.115. Error Connection reset by peer
[2011/02/14 18:46:24, 0] lib/util_sock.c:send_smb(871)
[2011/02/14 18:46:50, 2] auth/auth.c:check_ntlm_password(309)
[2011/02/14 18:47:30, 0] smbd/server.c:main(942)
smbd version 3.0.37 started.
Copyright Andrew Tridgell and the Samba Team 1992-2009
[2011/02/14 18:47:47, 2] auth/auth.c:check_ntlm_password(309)
Feb 14 18:47:08 NAS avahi-daemon[694]: Got SIGHUP, reloading.
Feb 14 18:47:08 NAS avahi-daemon[694]: Service group file /etc/avahi/services/cifs.service vanished, removing services.
Feb 14 18:47:09 NAS smbd[3061]: PAM pam_putenv: delete non-existent entry; KRB5CCNAME
Feb 14 18:47:31 NAS avahi-daemon[694]: Got SIGHUP, reloading.
Feb 14 18:47:31 NAS avahi-daemon[694]: Loading service file /etc/avahi/services/cifs.service.
Feb 14 18:47:32 NAS avahi-daemon[694]: Service "NAS (CIFS)" (/etc/avahi/services/cifs.service) successfully established.
Feb 14 18:47:59 NAS smbd[3189]: PAM pam_putenv: delete non-existent entry; KRB5CCNAME
eth0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
inet addr:192.168.2.100 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:7936 Metric:1
RX packets:4992 errors:0 dropped:0 overruns:0 frame:0
TX packets:2886 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2049130 (1.9 MiB) TX bytes:3491373 (3.3 MiB)
Interrupt:41
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:38918 errors:0 dropped:0 overruns:0 frame:0
TX packets:38918 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2697778 (2.5 MiB) TX bytes:2697778 (2.5 MiB)
JUMBO_FRAMES_eth0=1
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
