IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
siigna
Apr 12, 2011NETGEAR Employee Retired
Actually if anyone here that can replicate the issue has root access that'd be great. If you can increase the logging for samba and try connecting to the share, then send me the resulting logs that might be helpful here.
You can either increase the log level in /etc/samba/smb.conf (log level = 0 auth:2 should be the line), or send the smbd process a kill -SIGUSR1 to increase verbosity by one level (SIGUSR2 to decrease a level).
Log level 2 should give me enough information here, so either edit the config and reload samba/restart the NAS or send it the SIGUSR1 signal twice, make the connection and grab the log (/var/log/samba/log.smbd). Make sure to revert the changes afterwards else you run the risk of filling up the OS partition with logging.
Another thing that might be helpful here is a packet capture while trying the connection as well (with Wireshark or something of the sort).
