IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
WSJ
Jul 23, 2011Tutor
IanSav wrote: Hi,
My initial testing of the new 4.1.8-T5 beta RAIDiator seems to indicate that this issue has been improved if not resolved. This is *not* documented beta notes fix list.
Can others with this problem please try the beta, if practical, and let us know if this beta addresses the issues in your environment.
Ian.
Based on Ian's feedback, I've decided to give a try, as well. And I can confirm his good news.
So, everybody who is currently using 4.1.7 and suffering from the bug described in this thread: it's better to upgrade to 4.1.8 than to return back to 4.1.6. Whether you wait for the final version or dare to use the beta, is of course up to you. I was daring - and did not regret it (so far).
Regards, Wolfgang
PS: I'd appreciate if some of you would join Ian and me in testing the beta (click here) - the more of you are willing to give feedback the more likely it is that 4.1.8 will be released officially, soon.
