IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi, Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its ...
BadBrad
Aug 05, 2011Aspirant
This is very promising.
Does anyone have an approximate ETA as to when the 4.1.8 final will be available?
Also does anyone know if we will be able to upgrade from 4.1.6 straight to 4.1.8? I never did the 4.1.7 upgrade
One last question:
With version 4.1.6 I have had a problem when I use a scheduled power up. More often than not, I do not seem to get an IP address from the DHCP server on my netgear router when the unit performs its scheduled power up in the morning as it is power on but not accessible on the network. Other devices on the network do not have this problem. Please note that I always power up with a seagate exernal usb hard drive (formatted as ext 3) plugged into the duo. I have noticed that if I power down the system and immediately power it back up just after the external drive is shutdown, it usually comes back fine. Anyone know if this is a known problem that is fixed with 4.1.8? I also note that I have my router is reserving 192.168.1.3 for the duo, so it will always get 192.168.1.3 when DHCP is used.
--Brad
One last question:
--Brad
