jmalmlund
Jul 29, 2011Aspirant
4.2.18 kills Time Machine .sparsebundle
Just a word of warning to all that have updated to RAIDiator 4.2.18 and are using your ReadyNas as a Time Machine network drive. I had setup my Time Machine-backups using the "old way" of manually ...
jmalmlund
Jul 30, 2011Aspirant
mdgm wrote: Could you please try 4.2.19-T4 beta (http://www.readynas.com/forum/viewtopic.php?f=51&t=55394)and see if this fixes the problem? There is a fix relevant to using the same UID on your NAS and on your Mac
Please also note that updating to 4.2.18+ involves an update to the CNID database. If you have lots of files this can take a long time. Please be patient and wait for this to complete.
Also has guest access been enabled on your AFP shares due to bug in 4.2.18 (since corrected in 4.2.19)?
Didn't notice if there was any change when it came to guest access as I reverted down to 4.2.17 in hopes that it was just some freak issue with netatalk that prevented the sparsebundles from working correctly and now went strait to 4.2.19-T4
So now I'm at 4.2.19-T4 but I still get the "no mountable file systems" warning when I try to open the sparsebundles so I guess that I'll just have to accept that all my Time Machine backups are now gone :(.
