LaneHK
Jul 07, 2014Aspirant
516 Backup Issues
Hi All, I'm having problems with backup jobs on a 516 (6x2T) running 6.1.8. All of my jobs are backups from the same file server (running Win7x64). The first runs properly, always. The second, w...
mdgm-ntgr
Jul 21, 2014NETGEAR Employee Retired
You can still open an online support case at my.netgear.com after the 90 days are up. If you called support they should have told you about that option as well.
I would suggest you open an online support case and post the case number.
Also probably try 6.1.9 RC8. 6.1.9 RC8 won't truncate the backup job logs (I think) so may give better info as to what's going wrong if it still goes wrong on that.
