grahamu59
Nov 26, 2014Tutor
6.2.0 and antivirus updates
Since installing 6.2.0 36 hours ago virus definitions have failed to update with the error: System: Antivirus scanner definition file update failed due to downloading fail. Please check internet con...
RX
Nov 26, 2014Luminary
Hi,
I just want to check if have you tried to disable then re-enable the real-time antivirus scanning on System > Settings > Services on the NAS web-GUI?
