grahamu59
Nov 26, 2014Tutor
6.2.0 and antivirus updates
Since installing 6.2.0 36 hours ago virus definitions have failed to update with the error: System: Antivirus scanner definition file update failed due to downloading fail. Please check internet con...
peterkin
Nov 27, 2014Guide
This seems to be quite common - I had the same issue with one out of the two RN102s I've upgraded. It seems to be an issue with DHCP, as the static-addressed one had no issues while the other, on DHCP, had a problem.
