grahamu59
Nov 26, 2014Tutor
6.2.0 and antivirus updates
Since installing 6.2.0 36 hours ago virus definitions have failed to update with the error: System: Antivirus scanner definition file update failed due to downloading fail. Please check internet con...
jbee52
Dec 04, 2014Aspirant
Hi. Having same issue with an RN10200 - upgraded to OS 6.2 (eventually successfully!), Inet connection OK, email alerts working, LAN working but since OS upgrade antivirus update keeps failing. Tried dis & re-enabling real time antivirus scanning - no effect. Where do I find the DNS settings / 'router' field referenced above? Are these the ones listed under NAS GUI > Network > Settings > DNS? (currently listing WAN Primary & Secondary IPs)
