olest
Nov 25, 2014Guide
6.2.0 upgrade problem
After upgrading from my 312 from 6.1.9 to 6.2.0 and rebooting it just hangs with power led flashing. After 30 minutes I tried to power cycle it but still same problem. No respons to ping. Anyone ...
mdgm-ntgr
Nov 25, 2014NETGEAR Employee Retired
There was a large /var/log/syslog file. syslog must have been enabled at some point.
After removing this it installed 6.2.0 onto the OS partition successfully.
You also had this issue: http://www.readynas.com/forum/viewtopic.php?f=154&t=78628
If you wish to continue to use the iTunes service you should enable it on the Music share.
