Babbage
Dec 13, 2014Aspirant
6.2.0 upgrade problems on RN104
Since upgrading my RN104 to 6.2.0 I've had similar problems to those listed by other users: - Unable to shutdown or reboot. Display shows appropriate message and power button LED flashes, but noth...
Babbage
vandermerwe wrote: Yes try 6.2.1 RC2.
Do you have any apps installed?
OK, I'll do that when the files have been moved to drive 4 and backed up, and report back. Might be tomorrow at this rate.
Only one app is installed, Transmission 3.00.3, but has not been enabled for months. I'll remove it before upgrading the OS, just in case.
Thanks.
