Babbage
Dec 13, 2014Aspirant
6.2.0 upgrade problems on RN104
Since upgrading my RN104 to 6.2.0 I've had similar problems to those listed by other users: - Unable to shutdown or reboot. Display shows appropriate message and power button LED flashes, but noth...
mdgm-ntgr
Dec 21, 2014NETGEAR Employee Retired
Try running a balance on disk 4 (go to System > Settings > Volume Schedule and a schedule for a balance on the volume on disk 4.
Your volumes are quite full so it's quite possible your other volumes could encounter a similar issue at some point.
Do you have a backup of your data?
Why did you use a separate volume for each disk rather than e.g. a RAID-5 volume?
