Babbage
Dec 13, 2014Aspirant
6.2.0 upgrade problems on RN104
Since upgrading my RN104 to 6.2.0 I've had similar problems to those listed by other users: - Unable to shutdown or reboot. Display shows appropriate message and power button LED flashes, but noth...
Dec 22, 2014Guru - Experienced User
I use jbod on my backup NAS, and raid on the primary.
If you RAID-0 to span multiple drives, then a failure of any single drive will cause the entire array to be lost.
Although it can make your life a bit easier by eliminating the need to manually balance storage, the reliability price is pretty high.
>>>That would actually make my life easier as I wouldn't have to keep swapping drives when I do my backups.
I don't see how this is related to RAID-0 on the RN104, can you clarify?
